So I guess mods want no one to discuss Hauck or Glenn...
butteratgriz
Re: So I guess mods want no one to discuss Hauck or Glenn...
I'll talk about them. What do you want to talk about? Glenn retired and likely retired for good. Bob "Cat" Hauck hates MSU, but might hate UM worse after seeing the Griz presumably take Stitt over him.butteratgriz wrote:coaching the Cats?!?
- SonomaCat
If you've already had two threads moved on a topic (which is apparently what happened -- I didn't move them but it appears that a mod did) and then you go and post a third one, that tells me that you're just trying to be a pain in the arse.butteratgriz wrote:coaching the Cats?!?
Don't do it a fourth time.
butteratgriz
SonomaCat wrote:If you've already had two threads moved on a topic (which is apparently what happened -- I didn't move them but it appears that a mod did) and then you go and post a third one, that tells me that you're just trying to be a pain in the arse.butteratgriz wrote:coaching the Cats?!?
or what, you are gonna choose me for a fight after school??? Just messing with you guys, I guess you all don't have much of a sense of humor
Cataholic
Old news. Too bad we don't have a section on the board labelled "Just Plain Stupid Posts". Butteratgriz could be in charge of that section.butteratgriz wrote:SonomaCat wrote:If you've already had two threads moved on a topic (which is apparently what happened -- I didn't move them but it appears that a mod did) and then you go and post a third one, that tells me that you're just trying to be a pain in the arse.butteratgriz wrote:coaching the Cats?!?
