GoCats18
Post by GoCats18 » Sat Jan 18, 2025 12:27 pm
Anyone know if the same company that did the turf for the field will be doing the turf for the indoor practice field?
Punters are people too!!
Post by tetoncat » Sat Jan 18, 2025 1:39 pm
Why is there dirt inside. Will that be base for turf.
Post by AFCAT » Sat Jan 18, 2025 1:40 pm
Same as the football field in Bobcat stadium.
Post by AFCAT » Sat Jan 18, 2025 1:41 pm
Another shot from the East side. Lots of roof work to go.
Post by AFCAT » Sat Jan 18, 2025 1:48 pm
Some additional shots from the South and East sides. Lots of roof work to go.
Post by tetoncat » Sat Jan 18, 2025 1:50 pm
Didn't the IPF have a concrete floor? A base under turf makes sense, but if was already dirt why have the pile if concrete why put that under dirt?
Post by AFCAT » Sat Jan 18, 2025 1:58 pm
Part of it has a concrete floor. I'm assuming no concrete under the turf. Maybe an engineer could chime in, but why pour a bunch on concrete under the turf when you don't have to? The gris indoor doesn't have concrete underneath the field.
HelenaCat
Post by HelenaCat » Sat Jan 18, 2025 2:29 pm
The only concrete I saw was a footing across the field between each set of columns which acts as a structural component to resist vertical roof loads, etc. There may be some concrete near the walls but i did not see that earlier this fall.
Post by AFCAT » Sat Jan 18, 2025 2:35 pm
You can see the partial concrete floor In the picture I posted on the previous page. The concrete floor is in the throwing area though. I have my doubts there is a concrete pad under the turf, but I'm no engineer.
Reuben Kincaid
Post by Reuben Kincaid » Fri Jan 24, 2025 7:24 pm
Need to tap into some of that California money. Should be no problem to raise 20-50 million.
Post by CodyCat » Fri Jan 24, 2025 8:40 pm
What for?
Post by iaafan » Fri Jan 24, 2025 8:44 pm
Ha. Haha. Hahahahahahahahahahahaha!!!!
Post by iaafan » Wed Jan 29, 2025 10:29 am
Anyone had a chance to swing by the facility and see if it's showing any progress on the outside? I can't recall if the goal was to have it ready for spring ball or not?
Cats15
Post by Cats15 » Wed Jan 29, 2025 10:32 am
I recall hearing form someone with the university that sometime in March is the expected completion.
Post by iaafan » Wed Jan 29, 2025 10:39 am
Hmm, March is only 4.5 weeks away. I guess 8.5 if you count all of March. When does spring ball start?
Run-the-ball
Post by Run-the-ball » Fri Jan 31, 2025 7:54 am
Heard yesterday that the project is now behind. Hoping for it to open sometime in June. Bummed that it won’t be ready for spring ball, however, at least it isn’t another bubble like the griz got.
Post by AFCAT » Fri Jan 31, 2025 8:19 am
There are some pics on the previous page and this page that were taken less than two weeks ago.
HookedOnGriz
Post by HookedOnGriz » Fri Jan 31, 2025 9:18 am
I don’t know, doesn’t look too bad to me. Plus football, soccer, softball, and track and field have all been using it already. Whether it’s a bubble or different material, it’s finished and being utilized and 68 degrees. And the community schedule is filling up fast and bringing in extra $ to the university for rentals. I’m happy with it.
Post by MSU01 » Fri Jan 31, 2025 9:24 am
Both are good facilities although it's hard to argue that what MSU is building isn't better, so Bobcat fans will always poke a little fun at the Griz facility. Griz fans do the same with the football stadiums themselves, both are clearly in the upper echelon of FCS stadiums but yours is still the best of any of them.
Cats15
Post by Cats15 » Fri Jan 31, 2025 9:39 am
Does anyone know if MSU intends to rent out the space to the community as well?
