It's probably also that yours is kind of tucked away in the corner of campus and ours is very much out in the open with nothing really near itRainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
damnyoutuesday
When you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
You can see Wgs from the interstate if you know where to look but it’s obscured by the train tracks and power lines. It looks like it’s in an industrial area.damnyoutuesday wrote: ↑Mon Mar 31, 2025 4:32 pmIt's probably also that yours is kind of tucked away in the corner of campus and ours is very much out in the open with nothing really near itRainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
RainierGriz
Agree on the view from the interstate.iaafan wrote: ↑Tue Apr 01, 2025 10:47 amYou can see Wgs from the interstate if you know where to look but it’s obscured by the train tracks and power lines. It looks like it’s in an industrial area.damnyoutuesday wrote: ↑Mon Mar 31, 2025 4:32 pmIt's probably also that yours is kind of tucked away in the corner of campus and ours is very much out in the open with nothing really near itRainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
Well they are building something there.iaafan wrote: ↑Tue Apr 01, 2025 10:47 amYou can see Wgs from the interstate if you know where to look but it’s obscured by the train tracks and power lines. It looks like it’s in an industrial area.damnyoutuesday wrote: ↑Mon Mar 31, 2025 4:32 pmIt's probably also that yours is kind of tucked away in the corner of campus and ours is very much out in the open with nothing really near itRainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
- mslacatfan
It’s probably somewhere in these 80 pages…. But when is this expected to be completed?
FTG- GO CATS GO!
CatScratch14
I can confirm this as I open up my car window and fly the bird every time I drive through Missoula!iaafan wrote: ↑Tue Apr 01, 2025 10:47 amYou can see Wgs from the interstate if you know where to look but it’s obscured by the train tracks and power lines. It looks like it’s in an industrial area.damnyoutuesday wrote: ↑Mon Mar 31, 2025 4:32 pmIt's probably also that yours is kind of tucked away in the corner of campus and ours is very much out in the open with nothing really near itRainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
This summer.mslacatfan wrote: ↑Tue Apr 01, 2025 12:39 pmIt’s probably somewhere in these 80 pages…. But when is this expected to be completed?
Sounds like Rainier is describing how to build an outhouse.RainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
RainierGriz
*The nicest outhouse in the FCSSt George wrote: ↑Tue Apr 01, 2025 3:27 pmSounds like Rainier is describing how to build an outhouse.RainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
Great! Let's put that slogan on some t-shirts.RainierGriz wrote: ↑Tue Apr 01, 2025 4:38 pm*The nicest outhouse in the FCSSt George wrote: ↑Tue Apr 01, 2025 3:27 pmSounds like Rainier is describing how to build an outhouse.RainierGriz wrote: ↑Mon Mar 31, 2025 2:05 pmI think that is partially due to our field being quite a bit below ground level. Most of our seats are built into the ground also.
What is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
It’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
I hope they announce it soon, I am starting to turn blue from holding my breath so long.AFCAT wrote: ↑Tue Apr 01, 2025 6:42 pmIt’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
- CatBlitz
Those have needed replacing for about 20 years.St George wrote: ↑Wed Apr 02, 2025 8:48 amI hope they announce it soon, I am starting to turn blue from holding my breath so long.AFCAT wrote: ↑Tue Apr 01, 2025 6:42 pmIt’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
The flaws will probably buff out.CatBlitz wrote: ↑Wed Apr 02, 2025 9:10 amThose have needed replacing for about 20 years.St George wrote: ↑Wed Apr 02, 2025 8:48 amI hope they announce it soon, I am starting to turn blue from holding my breath so long.AFCAT wrote: ↑Tue Apr 01, 2025 6:42 pmIt’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
- The Butcher
Just slap a little paint on them, good as new!allcat wrote: ↑Wed Apr 02, 2025 11:29 amThe flaws will probably buff out.CatBlitz wrote: ↑Wed Apr 02, 2025 9:10 amThose have needed replacing for about 20 years.St George wrote: ↑Wed Apr 02, 2025 8:48 amI hope they announce it soon, I am starting to turn blue from holding my breath so long.AFCAT wrote: ↑Tue Apr 01, 2025 6:42 pmIt’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
I drove by yesterday and you souls see lights on inside hanging from the ceiling.
One thing that will be interesting is will snow stick to the roof or is it steep enough it just slides off? Because that roof will be dumping snow on the sides of the building where someone could be walking.
That reminds me of a time I saw a facility services van parked back behind the fieldhouse and it got absolutely demolished by a sheet of snow sliding off the fieldhouse roof.lutecat wrote: ↑Thu Apr 03, 2025 11:09 amI drove by yesterday and you souls see lights on inside hanging from the ceiling.
- CatBlitz
That's been the SOP for a decade+!The Butcher wrote: ↑Thu Apr 03, 2025 8:53 amJust slap a little paint on them, good as new!allcat wrote: ↑Wed Apr 02, 2025 11:29 amThe flaws will probably buff out.CatBlitz wrote: ↑Wed Apr 02, 2025 9:10 amThose have needed replacing for about 20 years.St George wrote: ↑Wed Apr 02, 2025 8:48 amI hope they announce it soon, I am starting to turn blue from holding my breath so long.AFCAT wrote: ↑Tue Apr 01, 2025 6:42 pmIt’s a stadium improvement being funded by a mythical game changing gift.allcat wrote: ↑Tue Apr 01, 2025 5:58 pmWhat is this mythical East grandstand you are referring to.TomCat88 wrote: ↑Tue Apr 01, 2025 9:43 amWhen you drive down Kagy from the east the stadium and now the IPF really pop out thanks to being up higher on Kagy. I really think it will look immense once the east grandstand is re-done with sky boxes. I'm assuming it will be as high as the EZ seating with skyboxes added to the top of that. The backside of the new grandstand would be like a huge billboard that MSU could get creative with.
