I worked at Stillwater mine for a bit and some of their shops underground could almost fit a football field. They could just leave the horses down there for old times sake and fans would be required to bring their own canary.MSU01 wrote: ↑Fri Apr 18, 2025 10:01 amYou guys aren't thinking big enough, I say MSU builds the world's first completely underground football stadium with tunnel entrances from all four sides of the field. Put a parking lot at ground level and you could charge thousands for fans to have a reserved parking spot at (above) the 50-yard line.
Cats92
- SACCAT
Cats92 wrote: ↑Fri Apr 18, 2025 1:10 pmI worked at Stillwater mine for a bit and some of their shops underground could almost fit a football field. They could just leave the horses down there for old times sake and fans would be required to bring their own canary.MSU01 wrote: ↑Fri Apr 18, 2025 10:01 amYou guys aren't thinking big enough, I say MSU builds the world's first completely underground football stadium with tunnel entrances from all four sides of the field. Put a parking lot at ground level and you could charge thousands for fans to have a reserved parking spot at (above) the 50-yard line.
Other than some slight concern about the four-sided goalpost this was exactly as I pictured it. Thanks, AI overlords!SACCAT wrote: ↑Fri Apr 18, 2025 1:20 pmCats92 wrote: ↑Fri Apr 18, 2025 1:10 pmI worked at Stillwater mine for a bit and some of their shops underground could almost fit a football field. They could just leave the horses down there for old times sake and fans would be required to bring their own canary.MSU01 wrote: ↑Fri Apr 18, 2025 10:01 amYou guys aren't thinking big enough, I say MSU builds the world's first completely underground football stadium with tunnel entrances from all four sides of the field. Put a parking lot at ground level and you could charge thousands for fans to have a reserved parking spot at (above) the 50-yard line.![]()
- RICO CAT
Can also be used as a shelter when the Yellowstone Caldera finally blows up.
Joe Bobcat
haha good catch. The cross bar doesn't appear to even be attached to the post from the ground either. There's no need to point out that the uprights are way too short, so I won't. Of greater concern though is there are the wrong number of yard lines unless my eyes are playing tricks on me.MSU01 wrote: ↑Fri Apr 18, 2025 1:31 pmOther than some slight concern about the four-sided goalpost this was exactly as I pictured it. Thanks, AI overlords!SACCAT wrote: ↑Fri Apr 18, 2025 1:20 pmCats92 wrote: ↑Fri Apr 18, 2025 1:10 pmI worked at Stillwater mine for a bit and some of their shops underground could almost fit a football field. They could just leave the horses down there for old times sake and fans would be required to bring their own canary.MSU01 wrote: ↑Fri Apr 18, 2025 10:01 amYou guys aren't thinking big enough, I say MSU builds the world's first completely underground football stadium with tunnel entrances from all four sides of the field. Put a parking lot at ground level and you could charge thousands for fans to have a reserved parking spot at (above) the 50-yard line.![]()
Some of you guys are offering up some crazy ideas. Is it just spring fever or have you all been hitting the booze, mushrooms or other psychedelics?
If you're looking for someone with a little authority, I'm your man. I have as little as anyone!
PHAT CAT
The cost to run the dewatering wells 24/7 would break MSU.
Perhaps all of the above! The way I figure it, making silly posts about underground football stadiums at least beats another week of fretting about the transfer portal before it finally closes for the season and we know for sure who will be on the team this fall.Joe Bobcat wrote: ↑Fri Apr 18, 2025 1:56 pmhaha good catch. The cross bar doesn't appear to even be attached to the post from the ground either. There's no need to point out that the uprights are way too short, so I won't. Of greater concern though is there are the wrong number of yard lines unless my eyes are playing tricks on me.
- D-Wreck
False. We build a hot spring facility above the thunderdome stadium. That practically prints money for us that we use for FCOA.PHAT CAT wrote: ↑Fri Apr 18, 2025 2:29 pmThe cost to run the dewatering wells 24/7 would break MSU.
4KornerKat
Unless we rename them geothermal wells. . . Then we could heat and cool campus with them!PHAT CAT wrote: ↑Fri Apr 18, 2025 2:29 pmThe cost to run the dewatering wells 24/7 would break MSU.
Joe Bobcat
Thanks for the pictures AFCAT.
It looks like on the westward facing wall there are windows way up high just a few feet below the roof that are somewhere around 3'-4' vertical and run nearly the entire horizontal length of that west wall.
It also looks like on the eastward facing wall there are vertical windows that are 3' -4' wide and are at least 10' tall probably closer to 18 feet tall spaced approximately every 40ish feet maybe about 8 of them on that wall.
The south wall looks to have a couple of long horizontal windows up as high as the west wall. The north wall looks like it has no windows. Oh the humanity!
If I'm at all close on my estimates of windows, then we're in pretty good shape with windows and natural light.
Remember they're going to be throwing the rock around in there and you know what they say about people in glass houses, so it might be good to not have too much glass.
Are the “windows” going to be glass or some other material that allows a diffused light in?Joe Bobcat wrote: ↑Sat Apr 19, 2025 1:47 pmThanks for the pictures AFCAT.
There is also going to be a big net around the field that lowers from the ceiling to catch any errant footballs. That will allow runners, etc., to safely use the track area while others use the field.Joe Bobcat wrote: ↑Sat Apr 19, 2025 1:47 pmThanks for the pictures AFCAT.
4KornerKat
They appear to be Kalwall windows or similar, so not clear.TomCat88 wrote: ↑Sat Apr 19, 2025 2:49 pmAre the “windows” going to be glass or some other material that allows a diffused light in?Joe Bobcat wrote: ↑Sat Apr 19, 2025 1:47 pmThanks for the pictures AFCAT.
https://www.kalwall.com/
A very quick video of the indoor. You can pause the vid though and see some of the field markings.
Those look nice. Looks like the entries on each end will have those over the doors to near the ceiling. I assume they allow in some heat but nothing like regular glass windows.4KornerKat wrote: ↑Sat Apr 19, 2025 4:17 pmThey appear to be Kalwall windows or similar, so not clear.TomCat88 wrote: ↑Sat Apr 19, 2025 2:49 pmAre the “windows” going to be glass or some other material that allows a diffused light in?Joe Bobcat wrote: ↑Sat Apr 19, 2025 1:47 pmThanks for the pictures AFCAT.
4KornerKat
Exactly. Better thermal performance, and diffuses the light to give daylight without glare.TomCat88 wrote: ↑Sun Apr 20, 2025 10:43 amThose look nice. Looks like the entries on each end will have those over the doors to near the ceiling. I assume they allow in some heat but nothing like regular glass windows.4KornerKat wrote: ↑Sat Apr 19, 2025 4:17 pmThey appear to be Kalwall windows or similar, so not clear.TomCat88 wrote: ↑Sat Apr 19, 2025 2:49 pmAre the “windows” going to be glass or some other material that allows a diffused light in?Joe Bobcat wrote: ↑Sat Apr 19, 2025 1:47 pmThanks for the pictures AFCAT.
Nothing new here, but Cats just posted this.
Will the Cat head logos that show in the rendering be part of final structure.
We'll find out in a few months.
