Mendenhall is a good coach. Nothing more.gris_h8er wrote: ↑Sat Aug 24, 2024 3:40 pmMendenhall is a world class coach. Vigen is not.The Butcher wrote: ↑Sat Aug 24, 2024 3:28 pmThink we are getting out-coached so far…
Hope the staff can adjust in the 2nd half.
The Offical-unofficial Bobcat—UNM Lobo gameday thread!
- BleedingBLue
Re: The Offical-unofficial Bobcat—UNM Lobo gameday thread!
Yes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
Defense: The series with young Grebe was encouraging. Need to play him more. I would start him, kid impressed me in two plays. Other than that glimpse of enthusiasm for the D they need to play better.catscat wrote: ↑Sat Aug 24, 2024 3:39 pmHope we bring up those grades in the second half.luckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:35 pmHalftime grades
Pass O - D
Run O - A
Pass D - D
Run D - C
Offense: RUN THE BALL, get Tommy out of the pocket and let him work. The running game will continue to open up the passing game as it did on the second scoring drive.
Only thing better than watching the gris lose is when the Cats win
Multiple PI calls. The only passes the UNM QB has not completed were when he made the wrong read or was inaccurate. Not sure there has been a single pass defended.luckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:41 pmYeah its pretty bad today. I hope they turn it around, but they've been a day late and a dollar short all day long.Prodigal Cat wrote: ↑Sat Aug 24, 2024 3:39 pmFIFYluckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:35 pmHalftime grades
Pass O - D
Run O - A
Pass D - F
Run D - C
Brewer/Owner Copper Furrow Brewing
Three time outs and clock stops to reset chains. That was a drive where running was 1000% an option.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
- catsrback76
Without Rylan Ortt this would be ugly Defensively! I will keep banging the drum that our LB’s are the key to how this D goes. We need BobbyD to dial in the LB’s. McCade has made a play or two, but Danny is invisible. Not sure if the injury messed with his head, but he needs some fire. Okay done with this rant…
We can win this game, but it will hinge on the Defensive adjustments and IF we stick to running first and throwing second!
- BleedingBLue
Doesn't mean you run to start the drive. If you run for 4 yards on the 1st play you either burn a TO or 15-20 seconds if you get a call in fairly quick. Nothing wrong with how they called that drive to start.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
- BleedingBLue
Nope, not to start the drive.gris_h8er wrote: ↑Sat Aug 24, 2024 3:44 pmThree time outs and clock stops to reset chains. That was a drive where running was 1000% an option.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
- mslacatfan
Defense needs to dial it in…. Been pretty uninspiring.
Offense should continue to roll.
FTG- GO CATS GO!
Humphrey goes for 8-12 yards in first down and you’d be singing a different tune.BleedingBLue wrote: ↑Sat Aug 24, 2024 3:45 pmNope, not to start the drive.gris_h8er wrote: ↑Sat Aug 24, 2024 3:44 pmThree time outs and clock stops to reset chains. That was a drive where running was 1000% an option.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
- utucats
Vigen has a 78% winning percentage but sure, he sucks.gris_h8er wrote: ↑Sat Aug 24, 2024 3:40 pmMendenhall is a world class coach. Vigen is not.The Butcher wrote: ↑Sat Aug 24, 2024 3:28 pmThink we are getting out-coached so far…
Run D was probably a B until we got suckered.Prodigal Cat wrote: ↑Sat Aug 24, 2024 3:39 pmFIFYluckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:35 pmHalftime grades
Pass O - D
Run O - A
Pass D - F
Run D - C
We really need to tackle better. Is getting pressure not good because of their huge OL?
Dial in the LBs by playing young Grebe more kid is a stud. Hustles and makes plays. I would start him right now.catsrback76 wrote: ↑Sat Aug 24, 2024 3:44 pmWithout Rylan Ortt this would be ugly Defensively! I will keep banging the drum that our LB’s are the key to how this D goes. We need BobbyD to dial in the LB’s. McCade has made a play or two, but Danny is invisible. Not sure if the injury messed with his head, but he needs some fire. Okay done with this rant…
They passed every play.BleedingBLue wrote: ↑Sat Aug 24, 2024 3:44 pmDoesn't mean you run to start the drive. If you run for 4 yards on the 1st play you either burn a TO or 15-20 seconds if you get a call in fairly quick. Nothing wrong with how they called that drive to start.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
Lack of pressure looks to be trying to get pressure with 4 guys. Has Vigen ever allowed a blitz to be ran in 4 seasons as coach?RickRund wrote: ↑Sat Aug 24, 2024 3:47 pmRun D was probably a B until we got suckered.Prodigal Cat wrote: ↑Sat Aug 24, 2024 3:39 pmFIFYluckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:35 pmHalftime grades
Pass O - D
Run O - A
Pass D - F
Run D - C
- catsrback76
Another bright spot…Brandon Hall is crushing it. Average on punts is over 50 and zero kickoff returns!
- BleedingBLue
And? We were 70 yards from the EZ. That's generally how 2 minute drives start.tetoncat wrote: ↑Sat Aug 24, 2024 3:48 pmThey passed every play.BleedingBLue wrote: ↑Sat Aug 24, 2024 3:44 pmDoesn't mean you run to start the drive. If you run for 4 yards on the 1st play you either burn a TO or 15-20 seconds if you get a call in fairly quick. Nothing wrong with how they called that drive to start.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
Running was an option and a damn good one in that drive they just refused to call the play.tetoncat wrote: ↑Sat Aug 24, 2024 3:48 pmThey passed every play.BleedingBLue wrote: ↑Sat Aug 24, 2024 3:44 pmDoesn't mean you run to start the drive. If you run for 4 yards on the 1st play you either burn a TO or 15-20 seconds if you get a call in fairly quick. Nothing wrong with how they called that drive to start.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
No one is arguing how it started. We’re complaining that they didn’t call a single running play the WHOLE driveBleedingBLue wrote: ↑Sat Aug 24, 2024 3:49 pmAnd? We were 70 yards from the EZ. That's generally how 2 minute drives start.tetoncat wrote: ↑Sat Aug 24, 2024 3:48 pmThey passed every play.BleedingBLue wrote: ↑Sat Aug 24, 2024 3:44 pmDoesn't mean you run to start the drive. If you run for 4 yards on the 1st play you either burn a TO or 15-20 seconds if you get a call in fairly quick. Nothing wrong with how they called that drive to start.tetoncat wrote: ↑Sat Aug 24, 2024 3:42 pmYes, had all 3 timeouts, no need to throw every play, but that has been MO under Vigen.
- technoCat
We blitzed on the one 3 and out we had in the second quarter I'm pretty sure. It was one of Dampier's wild over-throws.gris_h8er wrote: ↑Sat Aug 24, 2024 3:48 pmLack of pressure looks to be trying to get pressure with 4 guys. Has Vigen ever allowed a blitz to be ran in 4 seasons as coach?RickRund wrote: ↑Sat Aug 24, 2024 3:47 pmRun D was probably a B until we got suckered.Prodigal Cat wrote: ↑Sat Aug 24, 2024 3:39 pmFIFYluckyirishguy25 wrote: ↑Sat Aug 24, 2024 3:35 pmHalftime grades
Pass O - D
Run O - A
Pass D - F
Run D - C
DIE HARD CATS FAN SINCE THE DAY I WAS BORN
