I am attempting to put together a universal python code to rank players per position. I understand PFF is great but I am not paying $120 a year. If anyone would like to help or give me advice I am all ears... this is what I have for WR but AI helped me with most so it definitely could use some adjusting.
# Define player statistics (replace with actual data)
player_stats = {
"Receiving_Yards": 0, # Replace with actual value
"Receiving_TDs": 0, # Replace with actual value
"Avg_Yards_per_Reception": 0, # Replace with actual value
"Longest_Reception": 0, # Replace with actual value
"Rushing_Yards": 0, # Replace with actual value
"Rushing_TDs": 0, # Replace with actual value
"Punt_Return_Yards": 0, # Replace with actual value
"Punt_Return_TDs": 0 # Replace with actual value
# Add more statistics as needed
# Define maximum values for normalization
max_values = {
"Receiving_Yards": 1000, # Update with appropriate maximum value
"Receiving_TDs": 10, # Update with appropriate maximum value
"Avg_Yards_per_Reception": 20, # Update with appropriate maximum value
"Longest_Reception": 80, # Update with appropriate maximum value
"Rushing_Yards": 200, # Update with appropriate maximum value
"Rushing_TDs": 5, # Update with appropriate maximum value
"Punt_Return_Yards": 500, # Update with appropriate maximum value
"Punt_Return_TDs": 5 # Update with appropriate maximum value
# Add more maximum values as needed
# Define weights for each statistic
weights = {
"Receiving_Yards": 0.3, # Update with appropriate weight
"Receiving_TDs": 0.2, # Update with appropriate weight
"Avg_Yards_per_Reception": 0.1, # Update with appropriate weight
"Longest_Reception": 0.1, # Update with appropriate weight
"Rushing_Yards": 0.1, # Update with appropriate weight
"Rushing_TDs": 0.05, # Update with appropriate weight
"Punt_Return_Yards": 0.05, # Update with appropriate weight
"Punt_Return_TDs": 0.1 # Update with appropriate weight
# Add more weights as needed
# Function to calculate performance rating
def calculate_performance_rating(player_stats, max_values, weights):
normalized_stats = {stat: (player_stats[stat] / max_values[stat]) * 100 for stat in player_stats}
performance_rating = sum(normalized_stats[stat] * weights[stat] for stat in normalized_stats)
return performance_rating
# Calculate the performance rating
performance_rating = calculate_performance_rating(player_stats, max_values, weights)
print(f"Performance Rating: {performance_rating:.2f} out of 100")
I ran this for Ty McCullouch and got 42.29/100, Marvin Harrison Jr and got 85.05/100, and Bergen got 60.22 so it seems fair. I need help with the weights of the KPIs (Key Performance Indicators) and the max values for positions. THANKS!
Transfer Portal- Scoring Grade
Re: Transfer Portal- Scoring Grade
MSU TRANSFERS IN LAST 3 YEARS
Bolded players who were successful (in my eyes)
2023-4
In
Dylan Rollins (ol- BYU)
Alec Eckert (dt- Wash st)
Samora Ezekiel (ol- North Texas)
Rohan Jones (te- Maine)
Out
Christian Anaya (wr- Western Illinios)- Receiving-13.64 Rushing- NA
Aiden Parks (safety- Mt Tech)- no data
Garrett Coon (rb- SouthD)- Rushing-39.07 Receiving- 17.76 (2022 stats)
Kade Cutler (db- Montana)- limited data
Sebastian Valdez (dt- Washington)-
Kendric Bailey (safety-?)
Jace Fitzgerald (lb- Western)
Rush Reimer (ol- Cal)
Jacob Kettels (ol- Kennesaw St)
Omar Aigbedion (ol- Baylor)
2022-3
In
Ty McCullouch (wr- Colorado St)- Receiving-40.02 Rushing- -7.3
Blake Stilllwell (db- Navarro Juco)
Garrett Walchli (wr- Utah St)- NA
Cole Bullock (lb- Canyons Juco)
Lonyatta Alexander (wr- UW)- NA
Jon Johnson (cb- El Camino Juco)
Brenden Hall (kicker/punter- SMU)
Julius Davis (rb- Wisconsin)
Out
Eric Zambrano (db- ?)
Aaron Gerle (dt- NAU)
Isaiah Ifanse (rb- Cal)
Trey Yates (dl- MT Tech)
Blake Glessner (kicker- UCLA)
Dylan Snyder (wr- MT Tech)
Jaharie Martin (fb- Maine)
Malik Mullins (wr- ?)
Sean Austin (qb- ?)
Noah Smith (wr- ?)
2021-2
In
Dru Polidore (db- Air Force)
Sean Chambers (qb- Wyoming)- Passing-26.95 Rushing-59.72
Ravi Alston (wr- St Johns)
Omarrian Aigbedion (ol- Army)
Kaegun Williams (rb- San Diego St)
Malik Mullins (wr- Indepnedence CC)
Clevan Thomas (wr- Kentucky)
Rhedi Short (s- Arizona)
Out
Mathew McKay (qb- Elon)
Luke Pawlak (kicker- U Toledo)
Casey Bauman (qb- Augustans)
Cole Snyder (ol- Delaware)
Charles Brown (wr- Texas State)
Jaden Smith (wr- Tarleton)
TJ Session (ol- Cal)
Demarius Hosey (rb- Texas AM Commerce)
Jamahd Monroe (wr- ?)
Andrew Patterson (wr- ?)
2023-4
In
Out
2022-3
In
Out
Sean Austin (qb- ?)
Noah Smith (wr- ?)
2021-2
In
Out
I’d remove punt returns and make a separate category for punt returners. Then I’d take players with multiple positions and make a multi-position ranking by adding rushing, receiving and returns. This way you’ll have best receiving receivers, best rushing receivers, etc.
It’ll be cool to see who the best rushing receivers are.
- coloradocat
None of your bolds showed up.
Believe I fixed it
