SAT Scores
SAT Scores
I asked this over on the main board, but thought it'd be more appropriate here. What is a good SAT score? What is bad score? What do you have to score to be allowed into college in Montana, if you are from Montana? Any other general info would be appeciated.
Nevermind. I found this site via google. Pretty much spells it out.
http://www.montana.edu/mus/admissions.htm
- CelticCat
If you get less than 800 you basically flunked it. Don't you get like 300 just for spelling your name right, or was that just a myth teachers told students.
R&R Cat Cast - the #1 Bobcat fan podcast - https://www.rrcatcast.com
Twitter - https://twitter.com/rrcatcast
I believe that it this "myth" is corrrect, although the SAT people don't really care how you spell your name! From what I remember, it is impossible to score a zero on the SAT (i.e. you get a 300 or something like that even if you answer every single question wrong).CelticCat wrote:If you get less than 800 you basically flunked it. Don't you get like 300 just for spelling your name right, or was that just a myth teachers told students.
- Cat-theotherwhitemeat
- rtb
It was my understanding that there was going to be no math.wbtfg wrote:It doesn't count if you take the test twice, and then add the two scores together.Cat-theotherwhitemeat wrote:Damn, I only had a 1344 on my SAT but my ACT score of 34 made up for it.
My avatar does not now, nor has in the past, depict a person of mentally challenged state. If you have a problem with it, please call the U.S. department of Bite my A$$. MTBuff/Administrator.
mung
- New Recruit
- SonomaCat
